TwinTurbo.NET: Nissan 300ZX forum - I would assume when you try to start it..
Subject I would assume when you try to start it..
Posted by Draker (Eugene, OR) on April 01, 2010 at 4:50 PM
  This message has been viewed 92 times.
In Reply To I just replaced the starter relay and it still won't start posted by CaptainZappo on March 31, 2010 at 04:26 PM
Message You could hear the starter relay click, your relay might work fine but the power being switched to relay coil might not. I would assume if you've tested the starter with 12v and it cranks, and you've replaced the coil(Although not OEM), then test if the relay coil is getting voltage from the ignition switch when you turn the key to start. If it's not, you might need a new ignition switch.
